by Old geezer »
Thu Nov 06, 2008 9:26 pm
Hi all, I have a Baxi Bermuda gas fire/back boiler,potterton EP2002 controller,Honeywell F3-9513 2-port valve and Danfos seletric pump.I recently replaced the motorised valve motor (with a Synchron original) compatible one and all was well.But 5 days later the hot water didn`t work,(timer on) but CH was working fine.Now the pilot light won`t stay on longer than 1 minute after the burner kicks in. What`s causing this? I have noticed today that there`s an intermittent buzzing sound off the micro-switch on MV,but when manually pressed,you hear the water rushing through the pipes,so presume it`s working? Or should I just replace the whole motorised valve assembly? Would this stop the pilot light from staying on? Any help would be grateful,as I`m ggeeetttiinnngg ccccoolllddd, thanks.
