by htg engineer »
Sun May 27, 2007 1:27 pm
check water pipes are secure, normally just a pipe vibrating, against another or against joist or floor board. If pipes are secure see if they touch anywhere, and insulate or lag pipes with foam or something similar. or try closing the mains stop tap slightly just to reduce the pressure entering the property.
