Have purchasd a Honeywell wiring centre and intend to use it to wire C plan.
My system is a typical pumped CH and gravity HW with 2 modifications. I have a 2 port valve in the CH flow (to close Ch pipes in summer) and a pump in the Hw return (had problems with air locks in HW system)
I am assuming that the 2 port valve in th CH flow is wired to the HTG Valve on the wiring centre and the HW pump wired with the auxilliary from the HW valve.
My question is: Do the links to be cut alter from instructions if the above additions have been made?
