keston celsius 25 problem firing
baldilocks
by baldilocks » Tue Nov 25, 2008 10:04 pm
hi i have the unfortunate luck to own a house with the celsius 25 and have had experience with others on our estate.
the issue at the moment seems to be that it will not fire, it goes through the start up sequence but after the 4th attempt locks out, i thought aha thermo couple but it's electronic ignition, so phoned Keston direct and they said spark electrode, so after an almighty muck up on the behalf of HRP, i finally have one today a week later i've just fitted it and hey presto still doesn't fire, my meager conclusion draws me to gas valve as there is gas before the solenoid but nothing after or the pcb board as i haven't heard the thing spark (even tried it like you do with a car external with an earth point secured to it) help cause it's cold
Steve the gas
by Steve the gas » Wed Nov 26, 2008 5:45 am
Does the fan run?
warren jeffery
Re: keston celsius 25 problem firing
by warren jeffery » Wed Nov 26, 2008 7:28 pm
[quote="baldilocks"]hi i have the unfortunate luck to own a house with the celsius 25 and have had experience with others on our estate.
the issue at the moment seems to be that it will not fire, it goes through the start up sequence but after the 4th attempt locks out, i thought aha thermo couple but it's electronic ignition, so phoned Keston direct and they said spark electrode, so after an almighty muck up on the behalf of HRP, i finally have one today a week later i've just fitted it and hey presto still doesn't fire, my meager conclusion draws me to gas valve as there is gas before the solenoid but nothing after or the pcb board as i haven't heard the thing spark (even tried it like you do with a car external with an earth point secured to it) help cause it's cold[/quote]
check the fan pressure switch pull of the hose and operate it manually see if the boiler lights
