I have a vented hot water system.
I have just descovered hot water pouring out from my vent pipe into the expansion tank. I dont think I have a blockage and my boiler thermostate is working ok. The water level in the expansion tank remains constant as the water is returning into the system by the feed pipe.
I still get a hot water supply from the storage tank to the taps so the hot water from the boiler seems to have 2 flows. 1 through the storage tank, the other up the vent pipe.
I reduced the pump speed from 3 to 2 with no change.
I reduced the flow from the boiler through a gate valve already fitted. this seems to stop the flow up the vent pipe but now the water in the storage tank doesnt get so hot.
I think my problem may be due to the storage tank returm pipe only being 15mm with 3 right angle bends before converting back to a 28mm pipe, compared to the supply pipe from the boiler converting to 22mm from 28mm just before the storage tank. This may be restricting the flow of water directly back to the boiler forcing the water up the vent pipe instead.
Any comments please
