Ariston Heating problems even thou hot water works fine!
Posted: Fri Dec 05, 2008 4:40 pm
Hi all
Having some problems with my combi boiler ariston microgenius. Turning the hot water tap on ignites my boiler and gives me hot water everytime however trying to start the heating is a different story. After resetting the boiler it fires up the heating to max cause thats where ive set the main temp guage on the control panel to, pipes get real hot then after about a minute or 2 it just dies down. Ive just installed a new thermostat with new cable to the existing 2 core low voltage wire from the main control panel and I move the dial and still no heating. Now ive tried swiching it onto constant - doesnt work, timer on with timer set to present - doesnt work and the only one it works with is off! haha. Please help any ideas would be greatly app. By the way Ive removed all the rads bar 1 and both valves are opened, been bled and sitting at 1.5 bar.
