230V or Volt Free Stat which one do I use?
Posted: Sat Dec 20, 2008 12:13 pm
About 1 month ago I changed my old electr-mech Thermostat for a Digital Stat, it was easy to do, the new Stat a Sunvic 7501 required a 2 wire connection - Live and Call for heat, no neutral or earth was needed, 2 x AA batteries provoded the power to the Stat. Since installing the Sunvic it became obvious that the Stats position is just to near the kitchen door, when the door is opened the heat from the kitchen turns off the stat, keeping the kitchen door shut is not an option, moving the Sunvic is also not an option. The solution is a Wireless RF Stat, I can then place the Stat away from external heat sources.
The RF Stat I have found which is easy to use is the Salus RT300RF Model, the Installation instructions can be found if you visit "salus-tech.com/manuals" and then search for the correct manual.
I do not want a Programmable Stat, this model allows easy to use up - down and set options nothing else, anything that requires programming is a no no for my wife, she has a mental block on all things high-tech.
If you look at the installation instructions there are 2 options for wiring this model, 230v and volt free, bearing in mind how the current Stat is wired ie Live and Call for heat, am I right in assuming that the 230v wiring is the correct option for me. wiring in the L and N seems straightforward, but the Call for Heat wire is not so obvious looking at the diagram the SL position is where this wire would go. as the diagram states that * is not normallu used, which one do I use?
Any advice is apprecaited.
