by htg engineer »
Thu Jan 08, 2009 6:54 pm
Going off ?
Lock-out, pilot going off - or just not working ???
Lock-out or pilot going off - probably overheating, check the DHW flow switch, the flame should go out as soon as the tap is closed, if the flow switch or microswitch is sticking the boiler will stay on and overheat.
If it takes ages for the CH to start again after the tap has been running for a while - it may be that the wax capsule needs replacing. Or if you use a mixer tap, there's too much heat left in the boiler and pipework that the heating wont come back on until it has cooled.
Also with the Puma's a dripping hot water tap will stop the CH from working.
htg
