cold room hot radiator huge house!
Posted: Sat Jan 10, 2009 1:26 pm
We have a huge old house with 15 radiators all of different sizes. some rads get hot where others are cold (so we turned them off to try to increase temp in the others). We have bled all rads so no air and have just got used to a cold house. old boiler but gwo, pump has been changed also.
The main issue is that a baby is arriving and the room is freezing despite the rad being hot. question being is the rad too small for the room? I have worked out the btu and it needs to be 3196.8. (room size 3mx3mx3m high) the rad i have is a single 96cm by 60cm. should this be sufficient for this size room or should we change the rad or do we need the entire system examined - in other words is there a quick fix or will this be an expensive one!
Please help
Please help
