I have recently had a new Glow Worm boiler fitted to a two pipe vented system.
I am having to run the pump on setting 3 as when I switch to setting 2 the boiler immidately shuts down. On 3 I am getting hot water going up the expansion pipe into the tank and both the 15mm supply pipe and the expansion pipe get to hot to touch and my loft is full of condensation.
This problem seems worst when the hot water cycle is operating.
I have had the system power flushed on two occasions and had a Boiler Buddy fitted which is showing clean water in the system.
Can anyone help before I spend more money on the system.
