have indirect system with new boiler (4 years) and new pump (3 months). Probelm is that when central heating first comes on, it all works fine for about an hour then all radiators start to cool down. The boiler is still on and trying to heat water and the roomstat is still calling for temp to rise and pump is vibrating, though very hot. If I stop the pump by turning off heating on programmer, the motor burbles as it stops, the cold feed pipe down from roof tank starts to cool (was hot) and the expansion feed pipe starts to warm up. If I then restart the heating, pump again burbles, cold feed pipe heats up and expansion pipe cools down yet still no hot water being piped around radiators. I then have to stop the pum a second time, re-start and hot water starts to flow round radiators. The system was working fine until 2 months ago, when we had to fit a new pump. It's only since then that we are getinmg this "limbo" state where pump sounds and feels like it's pumping, but somehow, the hot water is not going round the radiator system. We've bled and balanced the radiators and i've checked there is cold water in the roof tank. I also notice that hot water is coming out of the expansion pipe into the roof tank, just a small dribble. I've tried seetting pump to each of it's 3 settings and medium and high power seem to get the radiators hotter than at low power. Someone mentioned that we may be sucking in air from somehwere or the vent pipe needs to be made much higher in the roof space before it returns it's end to the roof tank.
I'm pretty practical where plumbing is concerned buut this flumaxes me. My thoughts are that the pump goes into vibrate state after an hour as it gets pretty hot (on hot feed side of boiler), but no way of checking unless we replace pump with another.
any ideas appreciated. Martin
