hello all,
i have a conventional ch system - rads, boiler, f and e tank, room stat, pump, 3 way valve cylinder with coil etc.
the roomstat has 3 wires 1 red and 2 black, and when demand is turned off one of the black wires goes from live to off.
the problem is that when the room stat is turned down to zero demand for heating the rads are still piping hot.
the 3 way valve seems to be working as there is a whirring noise from that area.
the pump gets too hot too touch.
the 3 way valve was replaced about 18 months ago. the plastic drive had rounded off as the valve appeared to have been sticking so resisted being turned, i shall have to look at this again in case the valve is sticking again.
the system had 2 rads replaced 8 months ago, but has been working fine after that.
many thanks.
obm
