Replacing a Primatic based system
Posted: Wed Apr 01, 2009 5:48 pm
Due to a bad leak and probably age, I need to replace a Primatic and a water tank, both of which were leaking and have cause a ceiling to partially collapse. I have been informed that they can't be fixed even though the leaks are via connections to each cylinder/tank. Is this correct?
I have also been advised that since the boiler (a balanced flue Baxi) is old too it would be better all round to replace the lot with a combi boiler. Is this good advice bearing in mind that I might be able to either get the primatic and tank fixed, or just replace them.
