Electric Airing cupboard heater
Posted: Tue Apr 07, 2009 7:10 pm
I've just changed my back boiler and had the old hot water tank from the airing cupboard removed. It has been replaced by a Combi in the airing cupboard area (which I'm refitting with new stuff).
As the old "system" heated the airing cupboard area from the water tank typically, I need to replace that heat with a new system.
I've been looking at the following items :-
Google "hygienesuppliesdirect.com/products/prod132156"
and was wondering if this sort of size would be suitable for an area approximately 700mm wide x 400mm deep x 2000mm high, fitting the tubular heating arrangement on the wall at the very bottom. This area doesn't contain the boiler, and is empty space with slatted shelving being built.
I'm not really sure if the heat supplied will be enough, or indeed too much and perhaps get a single tube instead. I intend to use a timer control with it.
I'd be very grateful of any experience in this system, or any other suggestions.
