I just replaced one of my old radiators with a brand new one.
In order to replace it was necessary to bring the pressure in the system to zero but I haven't drain completely the system because I used coupling fittings.
I bleed the radiators and rise the pressure to 1 bar when cold.
[b]But the problem is the pressure now is rising to 2.5 bar at a temp. of 60 C only. [/b]
The boiler (is combi ) is the highest point of the pressure system and I'm thinking some air may went into the boiler and needs to be bleed.
Any ideas?
Thanks for your time
john d
