Radiator Valve Replacement
Posted: Fri Apr 17, 2009 4:16 pm
I have a radiator with the lockshield valve which has lost it's head. It was sheared off due to some heavy handed spanner work. Unfortunately it is currenlty closed and so unless someone can tell me a simple way to adjust the valve in it's current state I will need to replace the valve.
The system is an unvented s-plan with a greenstar (24i) boiler installed in the loft space. The advice on the site says to get a plumber in to do work on sealed systems. Is this a legal requirement or simply good advice due to the higher risk of getting wet while working with a presurised system (or another reason I have missed).
Assuming that there is nothing legally stopping me I have enough experience of plumbing to make me think I can do the job and wonder if someone could confirm my plan should work.
1) Switch off central heating system
2) Drain heating system (Unfortunatley the drain point is at the bottom of a different downstairs pipe run)
3) Open bleed valve on radiator whose valve needs replaced and loosen valve compression nut.
4) Catch remaining liquid which will drain from radiator and pipework.
5) Replace valve with identical replacement from DIY shed.
6) Close bleed valve and drain cock.
7) Introduce inhibitor to the system via a removed bleed valve on bathroom towel rail.
8) Refill system and bleed radiators. Refilling to 1.5 bar once radiators have been bled.
9) Run system for at least 2 hours and bleed radiators as required.
10) Increase presure as required to maintain 1.5 bars.
11) Over the following few days keep bleeding if required to remove all air from the system.
Assuming that I am not crazy to attemt this myself is there anything I have missed.
Thanks in advance for all your help.
