BOILER PROBLEM
Posted: Mon May 04, 2009 10:16 pm
by pauly1006
I HAVE JUST HAD A KESTON QUDOS 28H INSTALLED AND THE FAULT E12 KEEPS COMING UP, THIS SO THE INSTRUCTIONS SAYS A FLOW AND RETURN OVER HEAT THE BOILER IS OK SO IS THERE A PROBLEM WITH THE NEW PIPEWORK OR PUMP ETC
Posted: Tue May 05, 2009 10:25 pm
by bd3cc
Keston technical may well help. Number should be on the Literature left with you. Otherwise, call the plumber back
Posted: Wed May 06, 2009 5:30 am
by Steve the gas
Hi Pauly,
Firstly -caps lock off please - its regarded as shouting.
If the boiler says its overheating on flow and return - its prolly the boiler that is airlocked.
Bleed the pump, is the AAV open- does it have one?
Hth
