Results after a power flush?
Posted: Sun May 10, 2009 10:19 am
by Hadyn98
I was wondering what the water in the radiators should look like after a 'professional' power flush has been done?
I drained the entire system (to change the pump) after a company had been in to do a power flush, and the water coming out was brown. After refilling the system I went to look at the tank in the loft and it was still brown. Feeling around, I scooped up what must be metal deposits etc.
Is this normal? I was told by the engineer that the water was running clear after the power flush...
(In addition, most of the radiators were completely turned off, and I had to turn them on again before they heated up.)
£350 and I'm not very impressed.
Posted: Sun May 10, 2009 3:23 pm
by willie gas
hi i have never piped open vent pipe into the water in tank in loft, as it could drag dirt & crap into system. after power flush water in system will still be brown but most of the sludge should have been removed. it sounds like your c/heating system is piped up wrong.a good way to pipe up your system so you dont have pumping over or drawing air in is follow flow pipe from 3 port valve (the pipe which gets hot first) 1, 3 port valve 2, pump 3, tee which should be 22mm cold feed from tank in loft followed very close by 4, 22mm open vent pipe which goes up & over the tank in loft. all this might be in your airing cupboard. if the flow pipe is not arranged in that order you will get lot of air, noise & sludge. the sludge is the rotting of your system. GOOD LUCK.
Posted: Sun May 10, 2009 5:00 pm
by rosebery
How long did it take him to do the powerflush? How long ago was this done? A week, a month, a year ago or what?
If you have "brown" water in you header tank when you drain it the "brown" water will come out at the bottom.
A Powerflush won't clear the F&E tank out but I would say that that should have been done although it doesn't seem to have been.
Brown water indicates pumping over. Go in your roofspace and see if anything comes out of the vent pipe. If it does what is happeneing is that you are cycling hot water through the F&E tank and drawing oxygen into your system which is causing rust (= brown water) as it rots your radiators.
There are many thread here on the subject of pumping over. Do a search and you'll find both causes and solutions.
Efficiency of power flush
Posted: Wed Aug 12, 2009 8:35 pm
by oakesave
I came to ask the same question. Had a new combi boiler fitted three weeks ago. Not used the central heating yet. Removed the radiator in the room with new boiler to re-decorate and find water in the radiator is black with small particles. Is that normal?
Posted: Sun Aug 16, 2009 12:10 am
by plumbbob
It does depend on how much black is in the water. No central heating is going to be totally clear, but any large quantity of sludge can damage a condensing boiler's delicate heat exchanger.
Many engineers recommend fitting a Magnaclean to remove and prevent a build up of particles.
Posted: Sun Aug 23, 2009 11:23 am
by DEEARR2
It is standard practice and in accordance with manufacturers instructions that all new boiler installations have the heating systems totally flushed out prior to commissioning. Failure to comply could invalidate the warranty and have detremental effects on the boiler parts in the short tern. It would also be expected that a corrossion inhibitor be installed to help prevent sludge forming. I would suggest you refer to the benchmark notes left by the installer and confirm the system had been prepared for commissioning. If this is not available contact the installer. There is no way that the system water should be in the condition you mention in such a short period.
