A Rad only gets hot when boiler goes to Lockout!
Posted: Wed May 20, 2009 2:28 pm
I have an open vented CH system heated by a potterton suprima 40L. The system mainly runs ok with the exception of the Rad in the loft that only seems to heat up when the the boiler goes to lockout. I do the normal things like bleeding the rads to ensure that air isn't building up etc.
I have had the boiler's circuit board replaced and thermistor. The system has just been thoroughly Power Flushed and a magnaclean has been fitted.The air separator was also looking manky so it was removed and converted into an H plan configuration.
When the system was originally installed no bypass was fitted which seems to act as a heat sink which could be contributing to the lockout problem. This is a funny one. I think it could be an air lock but I'm scratching my head to be honest. Any thoughts??
Thanks :roll:
Thanks :roll:
