My boiler serves both CH and/or hot water via pump and motorised valve. It's now on hot water only via timer, but is cutting out after only 2 mins, and wont fire up again for another 10 mins, then on again for another 2 mins. One hour of timer provides 10 minutes of heated water. Pump is noisy, but this pipe run (water only) is fairly short and 22mm so airlock seems unlikely. At 10 years old could it be a blockage? Header tank (about 25 litres) contained a reddish/brown sediment which can only have come from expansion pipe from boiler. System did have Fernox put in when new but various plumbing jobs may have weakened it over time.
All references to sludge say it is black but what I took out (I emptied and cleaned the H&E tank) was 300 m/l of sediment.
Any suggestions as to possible cause and remedy (other than getting plumber in) very welcome.
