New boiler or keep existing one?
Posted: Fri Aug 21, 2009 12:35 pm
My wall mounted gas boiler (an Ideal classic) is 15 years old and located in the corner of the kitchen side on. If you want to look at the controls you need to peer sideways.
I'm in the process of designing a new kitchen and the location of the boiler is causing me great problems. I don't want it to be visible when the new kitchen goes in.
Q1 - Is a distance of 28cm between the edge of the existing cupboard and the boiler enough of a gap for some-one to be able to service the boiler?
Q2 - As it is 15 years old I wondered whether it needs replacing? I don't know how long they are supposed to last.
Q3 - If the boiler does need replacing, is it possible to get one which when fitted the controls would be visible from the front, would fit in a kitchen cupboard (special box) and NOT a combi boiler. How much would I be looking to spend for one to be installed. I do know some-one who works for British Gas, so would hopefully give me a bit of a reduction.
I hope this make sense. The property is a 2 bed townhouse.
Grateful for any replies
