Very confused - boiler man says its the valve - plumber says its the boiler!
1. Oil fired central heating.
2. Heating set to timed twice a day BUT goes off when it feels like it - although the programmer 'shows' that both heating and water are 'on'...the boiler is COMPLETELY dead. No lights on..no 'lockout' light on etc...and if you push the 'start' button..nothing. SOMETIMES it will start up again on its own!
3. This also happens if both switches for water and heating are set to 24 hours.
4. Motor in valve been replaced.
5. Boilerman says it HAS to be the motorised valve and the whole unit should be replaced.
6. On the valve we've tried taping lever over to the left - so in theory it should be constantly on. However last night heating went off...and valve still over on left!
7. Heating started as per normal this morning - when we checked the lever on the valve its broken free and is now over on the right.
At complete loss here ANY help would be greatly received!
