Towel Radiator not working
Posted: Tue Dec 29, 2009 4:55 pm
Can someone please help. I recently had a new bathroom installed by a professional. We wanted him to replace the old central heating radiator with a towel radiator. Which we asked him to move to the opposite wall, hence the plumbing was done as appropriate.
However he has now gone and I am left with a cold towel radiator! It is a ladder style towel radiator from B&Q.
I have bleed it for few hours today (few buckets) and it does get slightly warm after a while but not hot. The colour of the water is slightly golden however I gave up as this did get hot as the old central heating radiator used to. Not sure if it will go back to cold again after I stopped the bleed valve now.
We have a single pipe central heating system (I know what a nightmare!). British gas said it might be because he used a upvc pipe and this restricts the water flow for the towel radiator. Also the towel radiator is about 75cm off the floor hence the water would have to travel up the upvc pipe.
Can anyone help or suggest an alternative?
Many Thanks
Will
Many Thanks
Will
