Installing an extra radiator
patrickdowman@gmail.com
by patrickdowman@gmail.com » Mon Jan 11, 2010 5:29 pm
I want to install an extra radiator. Pipes are 15mm. How can I determine which of the two pipes I want to use is the 'out flow pipe' and which is the 'return flow pipe? Does it matter which way the water flows through the radiator? The radiator has no thermostat.
by stoneyboy » Wed Jan 13, 2010 9:06 pm
It doesn't matter which way round. If you want to fit a thermostatic rad valve buy one the reverse flow.
Re: Installing an extra radiator
by patrickdowman@gmail.com » Thu Jan 14, 2010 10:00 am
[quote="patrickdowman@gmail.com"]I want to install an extra radiator. Pipes are 15mm. How can I determine which of the two pipes I want to use is the 'out flow pipe' and which is the 'return flow pipe? Does it matter which way the water flows through the radiator? The radiator has no thermostat.[/quote]
Thanks for reply. Will agead confidently!
by patrickdowman@gmail.com » Thu Jan 14, 2010 10:01 am
Thanks for reply. stoneyboy, I will go ahead with confidence.
