1rad not hot
Posted: Thu Feb 04, 2010 10:58 pm
hi all my rads are ok they all have termo valves and anti tamper valves on the return which need a star key to adjust
but 1 rad wont get hot it was ok then just went off i have checked the valves all seem ok on the flow pipe there is a drain valve i put a hose on this and drained water then the water started to get hot and flowed through the rad but in reverse flow so it was returnin through the thermo
i let it run for a while then stopped it but within around 2 hrs it wen cold any help plz
