Combi boiler not holding pressure
Nozza
by Nozza » Sun Mar 14, 2010 7:31 pm
Hello,
My daughter has just bought her first house which has a combi boiler. The house was a repossesion and the heating system had been drained down for a while, possibly 4-5 months before they got the house. We have filled the system back up and it runs fine. However we keep loosing pressure over a period of about 1-2 hours. We have checked for leaks at all valves and fitting under the boards but can't see any signs of a leak. We have found all routes for the pipe-work to all rads and from the boiler, but no signs of any water. We have checked the Pressure release valve pipe-work and this is also dry. Has anybody got any ideas?
Darren
plumbbob
by plumbbob » Fri Mar 19, 2010 9:38 pm
Have you checked the condensate drain?
Trixsales
Loss of Pressure
by Trixsales » Sat Mar 20, 2010 12:13 pm
I had a similar problem with a Baxi 105E - after a great deal of time looking for leaks without success I eventually found that there was no pressure in the Expansion vessel - this turned out to be a leaking valve used to pressurise the vessel - the valve is similar to ones used on a car tyre. I used a car foot pump to take the pressure back up to 1 Bar. Since then no problems.
Rgds
Nozza
Found it
by Nozza » Mon Apr 05, 2010 8:12 pm
Thanks for you help, it was a leak after all. It was coming from the flow pipe at the connection to the boiler, I think the leak was so small the water was evaporating when the pipe-work was hot.
