nalaknip wrote:.......says you cannot have double radiators upstairs due to water and pressure issues. is this true?
Nope!
However, before changing or adding radiators you need to consider four things.
Has the boiler sufficient capacity to supply the extra output?
Are the supply pipes to the radiator sufficient to carry the extra capacity? (Usually yes).
Are the existing rads being heated fully and evenly over their entire surface area?
Now the last point and this is the tricky one.
The existing size of the rad should have been calculated to supply the correct amount of heat to that area. Randomly altering the sizes could be a recipe for disaster as it may unbalance the whole system making some areas red hot and others stone cold. Interestingly, it might not make any difference at all. It could also result in rooms being heated too quickly causing peaks and troughs in the temperature balance.
Look at the projects section for choosing radiator size. Follow the link to calculate the proper radiator size and compare it to those you already have fitted.
It is not common to see double panel rads in bedrooms unless they are very large or poorly insulated.
