Noisy boiler.
Posted: Mon Mar 05, 2007 4:09 pm
by Bob
I have a 12 year old Ideal Classic RS240 boiler. It started knocking about 4 weeks ago after I had it serviced by a plumber. I got the plumber back and he re-aligned the burner which 'appeared' to reduce the noise but now it is as noisy as ever. Any ideas would be appreciated.
Posted: Mon Mar 05, 2007 8:00 pm
by thedoctor
Take a look at the central heating projects on the website Bob. If you can't find the answer you can click through to the gas mans website and he will help you by email.
Posted: Thu Mar 08, 2007 5:06 pm
by Cpt Nemo
Hi Bob
Firstly - call the plumber back again. People should stand by their work, we do!
Secondly, it could be the result of air in the system, you do not say if it is a combi or system boiler.
Can you hear any other sounds which would indicate thate air was circulating around the system?
Posted: Fri Mar 16, 2007 12:31 pm
by thedoctor
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE
www.diydoctor.org.uk/projects.htm
