Do i need a flue liner? for woodburner.
geordiebilly
by geordiebilly » Sat Jul 10, 2010 10:29 pm
I currently have a gas fire with an open chimney and want to fit an inset woodburner, Do i need to fit a flexable duct/flue?
many thanks billy.
eggers
by eggers » Tue Jul 13, 2010 4:47 pm
not normally i believe, so long as the chimney is properly built, only applies if you changing from one gas appliance to another
Spankrino
by Spankrino » Sat Aug 21, 2010 9:27 pm
Not sure if I will complicate things but I am installing a wood burner into an existing fireplace and after so much reading I'm going blind, I believe you would need to install a liner.
Wood/Coal produces tar and other substances that will over time work their way into the flu brickwork and could, temp permitting reach its flash point and catch fire (aka chimney fire).
eggers
by eggers » Sun Aug 22, 2010 9:09 pm
then i stand corrected, i only work gas fires on them to fix or service them, during which i check the flue integrity and catchment area. Not yet installed one myself
Perry525
by Perry525 » Mon Aug 23, 2010 6:43 pm
How old is the house?
An old house will have a parged chimney.
A more modern one will be lined.
Each chimney is designed for a specified sized and type of fire. A modern chimney will have a plate showing the chimneys limitations.
You require council permission to change a chimney in any way, talk to them.
Only approved people may alter a chimney.
