Will a warranty be invalid if I don't have a system flush
Posted: Fri Jul 16, 2010 4:45 pm
by stuartcarr
I am about to have a new boiler installed. Only one of the three quotes includes a full system flush. If I choose NOT to have the flush, would the warranty on the new boiler become invalid? I appreciate the benefit of the system flush but the price just seems expensive. Also, if I did have the flush, would I also need a Magnaclean (think that's the name) adaptor installed in the system?
Posted: Fri Jul 16, 2010 9:32 pm
Ask all the installers, they should all flush the system and add inhibitor. It's ggod practice - and yes not flushing and not adding inhibitor can void warranty.
It's possible the expensive one has priced for a powerflush - unnecessary unless you have sludge issues.
Magnaclan is just a brand name, but yes it is worth fitting a magnaclean or something similar - like spirovent.
htg
Posted: Sat Jul 17, 2010 10:49 am
by stuartcarr
Many thanks HTG, you're correct, the quote was for a power flush. The reason I brought this question to the forum was because one manufacturer misunderstood the question, one said a powerflush was advised and another said it was essential. None of them actually answered the question about the lack of a powerflush invalidating any boiler warranty. Looks like I'm going to have to pay up.
Posted: Sat Jul 17, 2010 2:32 pm
No the lack of powerflushing doesn't invalidate the warranty - like I say powerflushing is very rarely required.
Flushing is as simple as filling and draining system, hot and cold to remove flux etc.
Powerflush - will be expensive - and probably not needed
Flush - should be standard practice.
htg
Posted: Fri Jul 23, 2010 6:17 pm
by eggers
depends on the state of the system, all manufacturer's state the system must be clean and recommend a powerflush. If a system is excessively dirty, it won't necessarily invalid the warranty, but it may not be covered under the terms and conditions of the warranty as the warranty covers mechanical failure, but if a component gets clogged up with muck and dirt, it can be considered to be working outside the conditions it was designed for.
i personally always recommend a magnetic filter of some description on the return the boiler
