Replacement Room Stat
Pipework
by Pipework » Wed Dec 08, 2010 2:43 pm
I require to replace a mechanical variant made by Process Control Gear, St Albans.
Can anyone recommend a reasonable priced replacement please.
The existing item has five connections marked as follows: -
E = Earth
2 = Cooling (not used in my set up)
1 = Heating (has a yellow covered wire connected)
N = Neutral (has blue covered wire connected)
3 = Line (has a red covered wire connected)
It appears to be mounted on a backing plate.
Regards
by sparx » Wed Dec 08, 2010 7:06 pm
this is an industry standard configuration and almost any stat can be used in place of it.
