external oil combi boiler
Posted: Sat Nov 19, 2011 10:38 pm
by macw
I'm about to have a new oil boiler fitted and have been given the choice between internal and external. Because going external would free up some space my wife would prefer that option, however, having read of various cold weather problems suffered by combi boilers in general over the last few winters I'm looking for advice as to how the externals cope. In particular in v. cold weather does the anti frost stat permanently trip(using more fuel) and is there a greater problem with condensate freezing. Any thoughts would be appreciated.
Re: external oil combi boiler
Posted: Sun Nov 20, 2011 8:54 am
by plumbbob
There are plenty of installations around that work just fine, but placing a boiler outside a living area is always going be a bit of compromise.
If the boiler is in the back of a garage that has tight fitting doors you might not see a problem at all. If the location is a drafty coal house, you may find in severe weather, an oil heater is required to prevent the pipe work from freezing.
Posted: Sun Nov 20, 2011 4:58 pm
by macw
Thanks for the reply Plumbbob, but I got the impression by 'external' my plumber meant literally outside, which was why I asked about coping with the cold especially after the last couple of winters where, locally, we've had several days at a time when the temp hasn't risen above freezing.
