Can standard underground clay pipe be used for chimney pot?
Posted: Thu Dec 01, 2011 7:53 pm
by kimbarton
Hi, I am fitting a new chimney liner (200mm) for new wood burner and find it impossible to get a chimney pot wide enough for the liner to fit through and be attached to the cowl, which in turn fits secured to the chimney pot. Does anybody knows whether a standard clay pipe can be used for a chimney pot? any help much appreciated..
Re: Can standard underground clay pipe be used for chimney p
Posted: Mon Dec 05, 2011 11:08 am
by bwhomeresponse
standard clay pipe is not meant to withstand a great deal of heat, even at the top of a chimney. have you tried reclamation yards..
Posted: Wed Dec 07, 2011 10:42 pm
by kimbarton
...got hold of a clay chimney liner 300mm depth by 200mm diameter, hopefully that should do the job?!
