central heating problems
Posted: Tue Jul 03, 2007 11:49 am
by r1mad
hi have this fault when put timer on get hot water but no radiators unless i turn motorised valve to manual
changed the motorised valve and the program timer but not cured this :?:
Central heating problems
Posted: Wed Jul 04, 2007 12:09 am
by DONFRAMAC
Sounds like it could be your radiator-system thermostat ;--- should be close to the controller, in the hall-way commonly. I have had to renew one myself, and found my old one was the wrong variant for boiler-fired central heating. The old one was suited to under-floor electric, and was missing the small heater/resistor below the bi-metallic strip type of switch.
The correct type gives finer control of temperature, like a cooker simmer-stat, but the other gives coarse control. At this time of year it may not kick-in at all, unless set higher than normal room-temp. I have read on these pages that the correct thermostat needs the earth connection wired-up for it to work properly.
Posted: Fri Jul 06, 2007 12:00 pm
by r1mad
yes was the thermostat thanks
