Questions about CH system upgrade
Posted: Fri Mar 30, 2012 8:40 pm
I need to replace a Glow Worm Fuel Saver B that heats my small 3 bed terrace house, and add a bathroom radiator. I am also interested in converting from an open vent system to a sealed system, although I definitely do not want a combi.
I would like to use an Intergas boiler, as I have heard about them on this forum.
My second choice would be Vaillant
Apart from that I wish to keep costs as low as possible and hope I will be able to retain at least some of the present control system and plumbing.
I wish to keep the boiler in the bathroom upstairs not least as it is next to the internal soil stack and condensate drainage would be simple.
My current system is fully pumped with a 3 port 3 position motorised valve, albeit now too stiff for the Duval motor to turn it. The positions are hw only, hw and ch, ch only
The hot water cylinder is in the upstairs airing cupboard in middle of house, with controls, 3 port valve and pump. I cannot see any bypass anywhere.
There are 5 radiators in the whole house. Each has a LSV and a wheel valve.
No TRVs. The room stat is downstairs.
The present control is a Potterton EP2000 via a Satchwell 437-2-802 wiring centre.
Recently fitted Grundfos 15-50 130 Selectric pump.
Downstairs rads are drop fed, no piping under the ground floor. I had thought about separate zoning for the bedroom circuit but all rads are currently mixed in the same circuit under the upstairs floorboards.
The narrowest piping is ½ inch.
I used an online heat loss calculator which came up with 4.18 KW for the house.
Could you advise if this is an S plan or Y plan? I think it is a Y plan.
I have contacted Intergas and they advise that their HRE 18 SB would be suitable, but if necessary I can stay with an open vent. The SB is downgradable to OV. I would like the Robokit with a view to putting the expansion in the airing cupboard.
I have no pump run on system yet but from what I can make out I can retain the Potterton controls as the pump run-on is controlled from the Intergas Boiler, I want to simply upgrade from the EP 2000 to the 6000. Is this correct?
I want to add a bathroom towel rail but not as a bypass circuit. I would want to turn it off in very hot weather. Can I have a wheel valve one end and TRV on the other?
I have read about Magna clean, Combi mate, Hydroflow hs 38 and Sesi Salamander but not sure what I need. My local water is hard, (Basingstoke)
I want the Magna clean but have to choose between Professional, Micro and Twin Tech models. I want the best and am prepared to have a Combimate or Sesi as well but don’t know if there is a need for this, in any case I want something to stop the hot water circuit scaling up as well. Can you advise on this? I will be having a power flush.
Would you advise replumbing from one three port valve to two separate two port valves, and would this mean getting a new control unit or wiring centre?
A local heating engineer advised that TRVs are not strictly required and the priority is to get the balancing correct. One thermostat and the rest TRV seems like a compromise, on an academic point only, would the best system be to have a separate MV for each rad and a thermostat in each room?
Many thanks for reading all this.
