Treehugger wrote:I have used the calculator you suggest but note that several others come up with different figures.
You will get different results from online calculators. It all depends on the assumptions they make and the methodology used. Some have glaring errors. The one I suggested has no errors, the methodology is correct and the assumptions are sensible.
My walls are also 600mm thick solid stone and the BTU calculator's don't have an option for this - again I am thinking that the thermal mass of the walls would have an effect on the BTU requirement[/quote]
The U-value of a 600mm stone wall is between 1.4 and 1.68. The on-line calculator uses these U-values: Brick cavity - 1.5; Solid brick 200mm - 2.1. If you entered 'brick cavity' into the calculator, you will get a result which is reasonably close to the correct loss for your room.
The thermal mass does not affect the heat loss; all it does is help iron out the fluctuations in internal temperature. Don't forget that the heat loss calculation gives you the amount of heat required to bring a cold house at -1C up to 21C when it is -1C outside.
