Noisy pipes!
Posted: Fri Mar 08, 2013 5:08 pm
by dwedmunds
When the central heating boiler stops there is a rumbling sound from the pipes, sometimes accompanied by a sharp knock sound. I can eliminate this by turning down the two gate valves on the pipes leading to the hot water tank in the airing cupboard but only if the valves are turned about 75% off. What causes this & how can I overcome the problem without having to turn the valves down so low? Apart from this the CH system works OK.
Re: Noisy pipes!
Posted: Mon Mar 11, 2013 12:57 pm
by diydoctor
Check out our project on Noisy Pipes https://www.diydoctor.org.uk/projects/noisypipes.htm
Thanks for posting
The Doctor
