Vailant Boiler Issue - System Dropping Pressure and Ejecting Water When Hot
Posted: Wed Jan 08, 2014 8:59 pm
Hi all,
I have a bit of an issue with my Vaillant TurboMAX Plus 837 combi boiler.
The system keeps dropping pressure. There is no leak, the water is being ejected via the 3 bar pressure relief valve but only when the water is hot. I have topped the boiler up at night (to 2 Bar) after it cools and in the morning the pressure has remained and no water has been ejected but when the boiler is on, the water pressure doesn't get above 3 bar but water is ejected even when the pressure only rises to 2 bar. There is air pressure in the expansion vessel.
The PRV is the prime suspect, but just wanted to ask if anyone had any other thoughts, just because it only passes water when the water is hot.
Thanks in advance
Al
Thanks in advance
Al
