21.5mm Trap for Heat Exchanger Fan Unit
carbar
by carbar » Wed Feb 19, 2014 7:18 pm
Hello.
I have just bought a heat exchange extractor fan that has an outlet for condensation which requires 21.5mm upvc pipe.
According to the installation instructions, I need to fit a trap to this outlet, but the only thing I can find is a straight-through trap (e.g. http://www.plasticdrainage.co.uk/condensate-straight-through-trap-21-5mm).
I'd rather have something more like a bottle trap or p-trap, but I can't see anything the right size.
Any suggestions?
Thanks,
Carl
proptech
Re: 21.5mm Trap for Heat Exchanger Fan Unit
by proptech » Thu Feb 20, 2014 8:03 am
Hi carbar
Just a thought, but how about making your trap with solvent weld elbows, and a compression coupler for maintenance.
carbar
by carbar » Thu Feb 20, 2014 9:15 am
Hello.
Thanks for the reply.
That is certainly an idea, although I can't see anywhere that supplies 21.5mm compression fittings. The closest seems to be push fit, which I suppose would be good enough for this.
Thanks,
Carl
