by somerton »
Wed Mar 21, 2007 3:33 pm
I am no expert but i think you should check your new pipework as it sounds as if you have connected the cold into the hot at some point which could push hot water back up from your cylinder to the tank.
The only other thing i could think of is if your system is overheating and boiling.
Surprised that you have not had more definite replies to this post.
Good luck.
