Can't Remove the Plastic Radiator Valve and the it is Leaking!
Posted: Thu Jun 05, 2014 5:30 pm
by denbob30
Help
My radiator valve is leaking from under the plastic cover. I can't seem to remove the cover to do any repairs that I have read to try. What can I do?
Re: Can't Remove the Plastic Radiator Valve and the it is Leaking!
Posted: Sat Jun 07, 2014 11:19 am
by proptech
Hi denbob30
If there's no screw in the top, then the cover will simply pull off. As far as the leak is concerned, try tightening the nut at the top of the valve. This usually solves the problem, otherwise it's a replacement valve.
Posted: Sat Jun 07, 2014 12:27 pm
by denbob30
That's what I thought and that is the case with other radiators in the house but not this one. It is completely stuck for some reason! I intend to try tightening the nut... When I can get to it.
Posted: Sun Jun 08, 2014 7:10 pm
by proptech
So if the others pull off, sounds like a bit more wellie is required. Let's face it, if you break the plastic, it's not the end of the world. The leak is the important point.
Posted: Sun Jun 08, 2014 8:37 pm
by denbob30
I don't mind breaking it... I just can't. What do you suggest I use?
Posted: Mon Jun 09, 2014 6:44 pm
by proptech
Difficult to say, as I've no idea what's in your tool kit. personally, I'd give the thing a good squeeze with a pair of water pump pliers.
