Public Male Toilet and Issue With Lack of Ventilation Causing Odours
Posted: Tue Aug 12, 2014 10:55 am
HI
i have a dilemma with a males public toilet in the i look after.
the problem is there is an ongoing smell of urine within this room, i have changed plus cleaned pipe work and traps as well as had new flooring laid. i had some one in looking at the ventilation as i heard that the smells could be due to poor supply and extract to the room.
the volume of the room is 928ft3 and according to the supplier of the extract fan the air change rat at the minute is 12 - 16 ac/ph but it was noted that the only supply to the room is a low level loovered grill on the bottom of the door which is 500 x 300 which leads to an internal corridor.
my question is could this be causing the fowl smell of the toilets and if a mechanical supply bringing in a fresh air source from out side would help clear it up.
