Radiators not all getting to temperature after fitting new boiler
Posted: Sat Nov 05, 2016 9:42 am
by RoyLittle0
Hi All,
I am having a few problems with my radiator system, I have had a new boiler fitted earlier this year and I have also fitted an additional radiator as well as rerouting the pipework to another.
My problem is that one room isn't getting to temperature, I have one radiator which is noticeably cooler than all the others.
The area that is the problem has 4 radiators T off in a close location to each other, probably they all Tee off within a 500mm area of the 22mm main pipe, could this cause one radiator to be bypassed by the main flow and just receiving a trickle from the Flow.
I have tried various things like turning radiators off and balancing the system which has improved things but not solved them, any thoughts?
The system is:-
    Combi Boiler "Potterton Titanium 33"
    22mm pipework for Flow and Return
    15mm Branch pipes to each radiator
    underfloor heating system
    It has been Flushed
    all radiators have been balanced to 1/2 turn on lockshield
    15 Radiator system
    Mainly all TRV's
Re: Radiators not all getting to temperature after fitting new boiler
Posted: Mon Nov 07, 2016 5:11 am
by lets have a look
turn off all the radiators including the bathroom except the cold one and see if it gets hot
