Hi ,hoping someone can throw light on this problem.
I switched off my boiler and drained the system in order to fit a new radiator downstairs. [Worchester 25si 15years old). After i fitted the new rad i went to the boiler and refilled to 2bar. Switched on boiler, and bled all rads in the house. After about 10 mins the upstairs rads were getting warm. Then i noticed there was a flashing light on boiler for the hot water supply.
I switched on taps in bath rooms to ensure there were no airlocks in system. Boiler worked fne for about 5min then flashing again started. I noticed b
oiler had also gone up to4bar. But i had switched off filler tap? Now the pilot wont light? I drained water from a rad to get pressure down which it did.pilot still wont light. Hope someone might help.
thanks.
