by Terryplaha »
Wed Jan 11, 2017 3:47 pm
Hope someone can help. No hot water from my Ideal Mexico 2 RS 60. Its a gravity system with 28 mm pipe to the tank and back to boiler. Recently I've power flush the central heating.There is no air lock in the coil in tank. When boiler is on water only the pump on the central heating is running, the radiators near the boiler starts getting hot, but not the up stairs ones. Is there an electrical fault or Is the 28 mm pipes are badly blocked.
