Honeywell 3 Port V4073A Motorised Valve and Issue With no Heating
Posted: Mon Jul 09, 2018 2:45 pm
Hi Everyone, I have an issue with my central heating system where I can turn on the water and the boiler hearts the water, if I turn on the heating the Honeywell 3 port V4073A motorised valve does not move the valve to heating even if the thermostat is set to max. This sounds like a simple job of replacing the synchronous motor. I though it may be the motor as when system is turned to heating I can move the lever over to the right and hey presto when I hear the relay click the heating comes on and the radiators get hot.
Now this is the unusual bit. Normally I read when people have this issue they move the valve lever over to the right and over the hook to hold the lever in the open position so they can get heating. For my situation, I don’t have to do this I move the lever to the right and when it clicks the micro switch the lever stays there on its own (No Need to hook it).
Also noted, if the heating is switched off the lever will stay where it is, if then the water is turned on the lever will come back on its own and water starts to heat. It appears there may be a voltage present to hold the switch in position but not move the motor. The valve seems to move ok (freely enough) as the spring obviously brings if back to enable the water to heat. If I turn all power off and the valve is set to heating the lever will fall back to the left, again making me think there is a voltage holding the switch.
I have replaced the motor with a new one and it made no difference.
The system has worked without issue for many years, and suddenly I had an intermittent period were occasionally the heating would not come on and over the last winter I have had to manually move the switch to bring the heating on, although recently while trying it before changing the asynchronous motor, one time the heating turned on correctly.
All wires in the wiring box and also the timer appear to be tightly screwed in and are never touched usually. The stat is an old square box Honeywell stat , I cleaned it out and checked it makes a good connection when on.
I am now thinking of changing the Honeywell powered V4073A as I see there is a small circuit board in the box under the lid. I can replace the head only as its the two screw version to the valve. Do you guys know why the valve switch can stay over to the right when manually moved and not being hooked, although if moved and stat is off (Temp already high) the switch will automatically come back on its own.
Many thanks for looking.
Simon
Simon
