fitting combi boiler
Posted: Fri Aug 31, 2007 8:35 am
by john_lumb
Can someone pls clarify: I'm working to a tight budget and feel competent enough to fit a combi boiler, obviously without connecting the gas or flue as that needs a Corgi engineer. Is it illegal to do all the other bits of installation, eg remove old boiler, connect to rads, water supply, fit themostat etc. Do you feel this would significantly reduce installation costs? Any advice would be appreciated.
installing a combi boiler
Posted: Sun Sep 02, 2007 10:50 am
by LES COWIE
What seems like a cheaper option at the start is not always the case. First job that needs done is the removal of the old boiler which means disconnecting the gas,[b] this must only be carried out by a corgi registered engineer[/b]. Best idea is to shop around for quotes and dont be embarrased to ask for corgi I.D.
Posted: Wed Sep 12, 2007 1:36 pm
by pepsi
yeh hes right if you start it nobody will touch it and you wont get any paperwork.......void insurance no certs for hibs ect
