Hi, Hope you can help complete novice diy guy! Cental heating all working fine, as is thermostat on strapped to immersion tank ( I think), as hot water appear to be at appropriate temp and gas boilers clicks on and off at appropriate juncture. However, when I attempt to use electric immersion heater (instead of gas) to heat water, water is extremely over heated and tank begins to shake and is very quickly turned off! Is this a big problem to repair. I dont any more information due to recently moving into home.
thanks
Davie
