Drayton DT20rF Receiver and Wireless Thermostat Advice
Posted: Sat Jan 18, 2020 12:05 pm
Hello,
Could do with some advice, please before I pick up a sledgehammer ;)
The boiler is Worcester Greenstar 28i Junior and I have a Drayton DT20rF receiver and wireless thermostat. I can't work out of the thermostat is on the blink. ....
The pairing, signal and placement are fine - green light and four arrows.
When the thermostat is set to 20c, it calls and the boiler answers. It calls until the thermostat reads 20c sometimes 20.5c and then stops calling and the boiler stops firing. Perfect. But then a short while later the thermo (still on 20.5) calls again and the boiler responds. Feels like the boiler is always firing every five minutes! Never goes to 21c
Is it just maintaining the temperature at around 20c? Old victorian house with bare floorboards e.g draughty and not great I suspect at holding its temperature.
The boiler never burns unless the thermostat calls or the hot tap is switched on, so I suspect the receiver is ok?
The other issue is sometimes when the thermostat is not calling it sounds like the boiler is burning, but when I check the green heating light, it isn't. It just sounds like it's running but not burning. Why would this be happening?
Can't work out whether to replace the thermostat? Replace the receiver and the thermostat or whether everything is fine....
Any advice greatly received.
Sam
Sam
