CH Pipe Tight up Against Floor Board Causing Expanding Clicks
Posted: Tue Apr 07, 2020 12:18 am
Hi all,
Had laminate flooring pulled up in favour of a new carpet being fitted and ever since the central heating pipe exiting the floorboard to the radiator has begun clicking when heating up.
Could well be a coincidence, but I've been back under the carpet to have a look at it appears the pipe is tight up against the bottom edge of the floor board as it goes through and curves (see pic).
I don't really have the DIY skills to start disconnecting CH pipes to make the hole larger, but wondered if anybody could think of a safe way to enlarge the hole while keeping everything intact.
Appreciate the help - see pic.
